2002 Ford Escort engine
JERRYL88
Engine Mechanical problem
2002 Ford Escort 4 cyl Automatic 137000 miles
I was driving 65MPH and suddenly it dropped to 20 MPH and then stopped completely. We put in a new starter and a new crankshaft position sensor and still the motor won't turn on. When we tried to turn it on it gave a small explosion type sould in the motor . Any ideas of what it might be?
Apr 29, 2009 at 8:32 AM
BMRFIXIT
  • 19,053 POSTS
Check oil
if low or no oil suspect bad engine
remove all drive belts place a socket and long hand ratchet on front crank pulley center bolt and try to turn engine can you
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 3, 2009 at 10:46 PM
