Truck was starting and running fine. Then a couple of months ago I was driving on the interstate around 70 miles per hour and it just quit running. So far I've swapped the fuel pump relay with a spare and it started and ran for about 30 minutes. I shut it off and tried to restart it but it was back to not firing. The engine was replaced about 3 years ago, I've had the coil packs replaced twice, and the fuel pump as well since the motor change. I believe the plugs and plug wires were also replaced.
Aug 31, 2019 at 11:07 PM
