Crank no start
186,152 MILES
JONESY8885
So I unhooked one side of the fuel line on fuel filter to drain the fuel. started and ran just fine. put the fuel line back on an now it cranks but wont start put fuel back in it. thanks
Aug 29, 2021 at 1:54 AM
  • 110,248 POSTS
The first thing we need to determine is if it is a fuel or ignition-related issue. Are you able to hear the fuel pump prime when you first turn the key to the run position?
Try this for me. See if the engine starts for a couple of seconds if you use starting fluid. If it does, then we know it is a fuel issue. If it doesn't, then we need to check for ignition spark.
Here are three links you may find of interest. One is how to test ignition spark, one is for testing fuel pressure, and one covers the most common causes of a crank no start condition.
If you are uncomfortable using starting fluid, use the links to check for fuel pressure and spark.
Aug 29, 2021 at 1:54 PM
