turn signals not working properly?
105,000 MILES • 2.8L • 4 CYL • TURBO • 4WD • AUTOMATIC
SCOTTDOG205
So, I just replaced all of the rear lights to my truck listed above z71 diesel with LED lights and all the lights work but i keep getting the rear turn single failure. it blinks 3 times normal then does a rapid blinking. what should i do to correct this problem? i have tried cleaning out the bulb inserts with contact cleaner.
Nov 11, 2023 at 4:01 AM
  • 55,616 POSTS
Yes, you must get the bulbs with the built-in resistor, or you will have this problem. Here they are on Amazon for $28.00:
https://amzn.to/468BcuU
Let us know if you need anything else.
Nov 11, 2023 at 7:28 AM
