2004 Chevy Colorado Turn signal click stops when brake is p
PHATTYJAY
2004 Chevy Colorado
My turn signal clicking noise gets bypassed when I push my break pedal down. When I press my brake, the turn signal click sound will click once when I push the brake down and then when I let the brake up it will make the sound again. When I’m sitting at a stop light with my left turn signal, the turn light will work, but the turn signal noise will not work until I let up off of the brake pedal. It also seems that the right turn signal is dimly lit periodically when the brake is pressed.
May 7, 2010 at 1:01 AM
HMAC300
  • 48,601 POSTS
check your grounds on the tailights. that may be why the one is dim. If not you might have a bad flasher.
May 16, 2010 at 10:52 AM
PHATTYJAY
I found the problem. It was a faulty pack for my trailer hitch lights. Once that was taken off and replaced, all was well. Thanks for the reply!
May 16, 2010 at 11:42 PM
HMAC300
  • 48,601 POSTS
glad you got it fixed, next time let us know if you have atrailer conection as well. Also when you have a trailer alot of times you need a more powerful flasher to operate the system..
May 17, 2010 at 6:12 AM
