Truck will not run
200,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
GANDERSON32
  • 9 POSTS
The Truck just coughed and shut off. so, believing that the fuel pump had failed, I bought a new one and installed it. ( it would start and run when gas was poured into the throttle body).However, it does not run now. I have changed computers, new fuel pump. I am at a loss, I think it might be in the wiring, but not sure. can you help?
Feb 24, 2018 at 2:19 AM
CARADIODOC
  • 34,415 POSTS
Double check that you have spark, then check the fuel pressure. You can have a loss of spark. It sounds like you have a loss of fuel pressure or injector pulses. By far the majority of crank/no-starts is caused by a loss of spark and fuel.
Also, listen for the hum of the fuel pump for one second when you turn on the ignition switch. If you hear that, the pump and its wiring are okay. Chrysler fuel pumps rarely fail while they are running. They typically fail to start up.
Feb 24, 2018 at 10:35 AM
GANDERSON32
  • 9 POSTS
I have spark, but no fuel, as the fuel pump will not run. I have the unit unplugged right now, and the only wire that lights up with my tester, is the "low fuel" light, even the tank is full, but only registers empty on the gauge.
Feb 25, 2018 at 12:33 AM
CARADIODOC
  • 34,415 POSTS
Are you aware the fuel pump only runs for one second when you turn on the ignition switch? A lot of people mistakenly think they can just turn the ignition switch to "run", then expect to find 12 volts at the fuel pump's connector.
Do you hear the fuel pump run for that one second? If you do, you're done in that circuit. It's working properly. If you don't or can't hear if the pump runs for that one second, find the fuel pump relay and bypass it. That will let you perform tests in the circuit at your leisure without even needing to have the ignition switch on. Your relay is plugged into the under-hood fuse box. Remove it, then use a jumper wire or stretched-out paper clip to connect terminals 30 and 87 together in the socket.
Now you can listen under the tank if the pump is running. If it's not running, check for 12 volts on the dark green / black wire in the pump's connector. You can use a digital voltmeter, but for this type of problem, a test light will be more accurate. Let me know what you find.
Feb 27, 2018 at 3:23 AM
GANDERSON32
  • 9 POSTS
Whenever I use the "stretched out paper clip" I can hear a clicking on noise somewhere on the left side of the engine, however, I cannot hear the pump run. I will get to the wiring sometime today. I hope then I can find the problem. Thanks so much
Feb 28, 2018 at 1:54 AM
CARADIODOC
  • 34,415 POSTS
Sometimes you can hear the hiss at the fuel pressure regulator when you bypass the fuel pump relay. That is from the fuel flowing through the spring-loaded valve in the regulator. It's on the fuel rail that runs between the injectors. That will tell you the pump is running. Chrysler fuel pumps are built to very tight clearances which makes them relatively quiet and hard to hear.
Feb 28, 2018 at 9:14 AM
GANDERSON32
  • 9 POSTS
I'm sorryI drug my heels on responding, but the answer just popped out at me, while I was doing checks on the primary circuit.. Had to be in the wiring, and turned out it was, two broken wires in the wiring loom. I tracked them down and repaired them, started right up, so all is good right now. Thank you very, very much
Mar 8, 2018 at 12:37 AM
  • 55,748 POSTS
CARADIODOC is one of our best!
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Mar 10, 2018 at 3:51 AM
CARADIODOC
  • 34,415 POSTS
No, no, no. That can't be the solution, . . . because I didn't think of it!
Oh well. Very happy to hear you solved it. Come back and visit us again.
Mar 11, 2018 at 10:05 AM
  • 55,748 POSTS
lol good times here @ 2Carpros!
Mar 12, 2018 at 4:29 AM
