1992 Dodge Dakota Will not Start
DIG2WIN
  • 1992 DODGE DAKOTA
  • V8
  • 419,543 MILES
I have accessed the code and the first set of flashes are 3 and then it pauses then gives me 5 more flashes and then pauses and gives me 5 more flashes. Anyone know what this code means? Any help would be greatly appreciated.
Monday, June 7th, 2010 AT 7:02 PM
1992 Dodge DTC's
11 Engine has not been cranked since battery was disconnected.
13 MAP sensor pneumatic circuit.
14 MAP sensor electrical circuit.
15 Vehicle speed/distance sensor.
17 Engine running too cool.
21 Oxygen sensor circuit.
22 Coolant temperature sensor circuit.
24 Throttle position sensor.
25 IAC motor driven circuit.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
32 Fault in EGR diagnostics.
33 A/C cutout relay circuit.
35 Fan control relay circuit.
41 Charging system excess or no field current.
42 ASD relay circuit.
43 Fault in ignition coil control circuit.
44 Battery Temp Voltage.
46 Battery voltage too high.
47 Battery voltage too low.
51 Oxygen feedback system stuck at lean position.
52 Oxygen feedback system stuck at rich position.
53 Internal logic module problems.
54 Fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Indicates unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller
Monday, June 7th, 2010 AT 7:57 PM
