Truck will try to start on its own
BROKENTRUCK99
  • 1999 FORD F-350
Truck will try to start on its own. Have burnt up 2 starters and 2 solenoids.
have to disconnect batteries when not using it.
the last time it did it also burnt up window control switch in drivers door.
have had issues with steering column. The starting on its own started after that.
will not do it all the time.
Saturday, May 4th, 2013 AT 6:25 PM
  • 52,797 POSTS
You have a short in the column from your description. Get this attended to asap ans you may be doing damage to the harness.
Saturday, May 4th, 2013 AT 7:12 PM
BROKENTRUCK99
The last time we had the electrical issue it screwed up the window controls. Any ideas on how to fix. Replaced control panel on door but they still do not work.
Monday, May 6th, 2013 AT 4:35 PM
  • 52,797 POSTS
Dont even know the issue. We are eliminating the possibilities here. We cannot see it or touch it. You need a electrical shop to confirm the issue then we can talk money, time and a resolution
roy
Monday, May 6th, 2013 AT 4:50 PM
