After sixty mph the transmission has a shifting issue
  • 52,797 POSTS
No, it would cause the fluid to heat up and you would notice it burned color or varnish.
Wednesday, January 9th, 2019 AT 12:12 PM
MICHAELNOCITA
  • 18 POSTS
Okay. Thanks
Wednesday, January 9th, 2019 AT 12:19 PM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Wednesday, January 9th, 2019 AT 12:21 PM
MICHAELNOCITA
  • 18 POSTS
Would a bad shift seal leak fluid an cause transmission problems?
Wednesday, January 9th, 2019 AT 7:17 PM
  • 52,797 POSTS
Only if the leak is enough to allow the fluid to be low enough that the transmission will not engage into gear.
Thursday, January 10th, 2019 AT 4:48 AM
MICHAELNOCITA
  • 18 POSTS
Okay. It's not that then because it doesn't leak. Thanks
Thursday, January 10th, 2019 AT 5:43 AM
  • 52,797 POSTS
Okay, why did you ask that if it is not leaking?
Thursday, January 10th, 2019 AT 6:12 AM
MICHAELNOCITA
  • 18 POSTS
Because I figured that it could make the shift loose by the seal being bad.
Thursday, January 10th, 2019 AT 7:17 AM
  • 52,797 POSTS
Lets get back to the issue.
What about the cable for shifting? You said you were going to check it and adjust it.
Any results?
Thursday, January 10th, 2019 AT 7:40 AM
MICHAELNOCITA
  • 18 POSTS
Haven't done it get. Don't know which direction to turn what every it is that needs to be turned. I found where to adjust it but have done it yet.
Thursday, January 10th, 2019 AT 7:49 AM
  • 52,797 POSTS
You can move it one way and drive it. You should see a difference in the shift points. If it makes the issue worse, then go back and adjust the cable the opposite direction until the shift points are correct.
Thursday, January 10th, 2019 AT 7:51 AM
MICHAELNOCITA
  • 18 POSTS
Okay. I'll try it out when I can. Thanks
Thursday, January 10th, 2019 AT 8:02 AM
  • 52,797 POSTS
You are welcome.
Thursday, January 10th, 2019 AT 8:10 AM
