After sixty mph the transmission has a shifting issue
360,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
MICHAELNOCITA
  • 18 POSTS
I replaced all the sensors, torque converter, an solenoid pack. It goes 60 mph fine. I have to let off gas pedal when trying to get up to speed little quick and press it again so, it can shift gears. Can you help me figure it out?
Jan 3, 2019 at 12:11 AM
Good morning,
Does it shift through all the gears?
I need more information. what is the exact issue?
How long since you changed the oil/filter in the transmission?
Jan 3, 2019 at 1:03 AM
MICHAELNOCITA
  • 18 POSTS
I just put new oil in about two months when I put new torque converter thing that was my problem. Even though that was one issue that did need to be done. It will shift through all gears but it only does when I let off gas and press gas in again. It will stay in gear at high rpm's until I do as I said. But if I ease into the gas pedal it will shift on its own. Just not when you try to get up to speed little quicker.
Jan 3, 2019 at 1:29 AM
Okay, is the check engine light on? are there any codes?
There is a transmission shift cable attached to the throttle body linkage. are the brackets tight and the cable connected?
Jan 3, 2019 at 2:48 AM
MICHAELNOCITA
  • 18 POSTS
No, codes. I have not checked all that. I did have someone tell that it could be the shift cable. I reput on the cable after I took transmission out to replace the torque converter in it. Could the cable be a problem?
Jan 3, 2019 at 3:30 AM
Yes it could as it controls the throttle valve which controls the shift points.
Jan 3, 2019 at 3:32 AM
MICHAELNOCITA
  • 18 POSTS
Okay. I was thinking it would be the valve body clogged, but I try shift cable and linkages first. Thanks
Jan 3, 2019 at 6:16 AM
Okay, you are welcome.
Always glad to help.
Jan 3, 2019 at 7:51 AM
MICHAELNOCITA
  • 18 POSTS
I forgot that when I go up hills my truck would only go 25-35 mph to go up. Would that still be linkage?
Jan 5, 2019 at 4:09 PM
no, does it downshift to a lower gear?
is the engine running okay?
https://www.2carpros.com/articles/engine-has-low-power-output
Jan 5, 2019 at 8:31 PM
MICHAELNOCITA
  • 18 POSTS
Engine runs fine. As far as I know it's something with transmission. It does high rpm's at time in a gear until I let off gas and press it again to shift in a gear. I don't think it down shifts like it is suppose to.
Jan 5, 2019 at 11:11 PM
MICHAELNOCITA
  • 18 POSTS
The only codes are for o2 sensors an evap large leak. There's no other codes on my truck. It has a timing chain. Could the chain jump a tooth without putting a code?
Jan 5, 2019 at 11:22 PM
MICHAELNOCITA
  • 18 POSTS
If I go 65 mph it jerks back and forth.
Jan 5, 2019 at 11:28 PM
This is a transmission issue.
Did you try adjusting the shift cable?
Jan 5, 2019 at 11:31 PM
MICHAELNOCITA
  • 18 POSTS
That I have not done. I was looking at getting a new one. I'm going to look at that an the linkage areas. when I get the chance to. Could the valve body cause any of the issue to?
Jan 6, 2019 at 12:34 AM
yes it could but need to start somewhere.
start with the cable adjustment.
Jan 6, 2019 at 12:49 AM
MICHAELNOCITA
  • 18 POSTS
Okay. Thanks. I'll also, get new bushing pieces for the linkage.
Jan 6, 2019 at 1:10 AM
Sounds like a plan.
Jan 6, 2019 at 2:17 AM
MICHAELNOCITA
  • 18 POSTS
Thanks again.
Jan 6, 2019 at 9:49 AM
You are welcome.
Glad to help.
Jan 6, 2019 at 9:57 AM
MICHAELNOCITA
  • 18 POSTS
Could a clog transmission fluid cooler affect the transmission?
Jan 9, 2019 at 3:28 AM
No, it would cause the fluid to heat up and you would notice it burned color or varnish.
Jan 9, 2019 at 4:12 AM
MICHAELNOCITA
  • 18 POSTS
Okay. Thanks
Jan 9, 2019 at 4:19 AM
You are welcome.
Jan 9, 2019 at 4:21 AM
MICHAELNOCITA
  • 18 POSTS
Would a bad shift seal leak fluid an cause transmission problems?
Jan 9, 2019 at 11:17 AM
Only if the leak is enough to allow the fluid to be low enough that the transmission will not engage into gear.
Jan 9, 2019 at 8:48 PM
MICHAELNOCITA
  • 18 POSTS
Okay. It's not that then because it doesn't leak. Thanks
Jan 9, 2019 at 9:43 PM
Okay, why did you ask that if it is not leaking?
Jan 9, 2019 at 10:12 PM
MICHAELNOCITA
  • 18 POSTS
Because I figured that it could make the shift loose by the seal being bad.
Jan 9, 2019 at 11:17 PM
Lets get back to the issue.
What about the cable for shifting? you said you were going to check it and adjust it.
any results?
Jan 9, 2019 at 11:40 PM
MICHAELNOCITA
  • 18 POSTS
Haven't done it get. Don't know which direction to turn what every it is that needs to be turned. I found where to adjust it but have done it yet.
Jan 9, 2019 at 11:49 PM
You can move it one way and drive it. You should see a difference in the shift points. if it makes the issue worse, then go back and adjust the cable the opposite direction until the shift points are correct.
Jan 9, 2019 at 11:51 PM
MICHAELNOCITA
  • 18 POSTS
Okay. I'll try it out when I can. Thanks
Jan 10, 2019 at 12:02 AM
You are welcome.
Jan 10, 2019 at 12:10 AM
