I checked fuel pressure its 13 pounds changed erg valve I noticed brake booster was making a hissing sound when you apply brakes and when idling the motor changes idle also so unplugged vacuum hose to brake booster and drove it run better wasn't falling on face and didn't have to feather gas pedal if the brake booster is bad will it take to much vacuum from the motor to make it run like a bad fuel pump
SPONSORED LINKS
Tuesday, September 1st, 2015 AT 8:39 AM
