2005 Chevy Silverado gas peddle vibration
78,000 MILES • V8 • 4WD • AUTOMATIC
JACKIEY60
  • 5 POSTS
When driving over rough roads, a vibration can be felt in the gas peddle. We have had the front end suspension parts checked and all bolts under truck tightened, including transmission mounts . We have had 4 new shocks put on. Our mechanic can not think of anything else. The chevy dealership suggested maybe ourt after market side bars are the problem. Anyone have ideas?
Aug 12, 2010 at 10:35 AM
  • 110,248 POSTS
Have you checked motor mounts? Also, has what do you mean by aftermarket side bars, running boards?
Aug 15, 2010 at 2:06 PM
JACKIEY60
  • 5 POSTS
yes motor mounts checked. The side bars have th same purpose as runniong boards. They are tubes that run below the doors you step on to get in the truck.
Aug 16, 2010 at 12:26 AM
  • 110,248 POSTS
This is an interesting one. As far as the running boards, I can't see how they would cause this. I have to ask one last question. When you feel this, does the engine continue to run smoothly, or do the RPM's change?
Aug 16, 2010 at 4:06 PM
