Battery light on?
DSTAM932
  • 2004 CHEVROLET SILVERADO
  • 6.6L
  • V8
  • TURBO
  • 4WD
  • 268,000 MILES
Install new alternator working great and charging, but the battery light will not go off, tried to locate alternator
fuse no luck. Found battery fuse under the hood in the fuse box, fuse is good, Don't where else to look.
Thursday, September 3rd, 2020 AT 6:23 PM (Merged)
JDL
  • 16,098 POSTS
Did you check for applicable trouble codes? Some of the national brand autostores will check codes for free. Check manufacturer specific codes as well as po codes.
Our database says to use a scanner that will show live engine data for your vehicle, check ipc, instrument panel cluster pids, if the charging system reading is correct and the lamp is on, replace the ipc. I won't replace anything unless diagnostics point me in that direction.
DSTAM932
I have a Edge programmer the code was PO621 Generator L
Terminal Circuit, Generator not charging, placed Volt meter on battery
with engine running, shows 14 amps also the volt gauge in truck also shows 14 amps. Could I disconnect both battery cables wait 10 minutes
and let the computer reset?
Dale
JOHNBISHOP70
  • 2005 CHEVROLET SILVERADO
  • 6.6L
  • 6 CYL
  • 4WD
  • 230,000 MILES
When I turn my truck off, the red battery light in the upper right hand part of the cluster comes on and stays on. Is this normal? My truck listed above is a 2500HD with Duramax 4x4.
  • 52,797 POSTS
Good morning,
Is the light on without the key in the truck?
If the light is on, then the alternator is the issue.
If it is not, then with the engine not running, the light being on is normal.
https://www.2carpros.com/articles/how-to-replace-an-alternator
