code P2610
13,280 MILES • V8 • 4WD • AUTOMATIC
LIGHTNING101
I have a diagnostic code reader that came with my Quadzilla programer for my diesel motor, every once in a while the check engine light will come on, and when I run the diagnostic portion of the programer the number 2610 comes up. Would you be able to tell me what 2610 means.
Dec 9, 2007 at 5:18 AM
DENNYP
  • 1,824 POSTS
Important: DTC P2610 can be set with a loss of battery voltage to the ECM with the ignition ON. The ignition must be in the OFF position before disconnecting the ECM.
If DTC P2610 is set, turn the ignition OFF and then completely disconnect the ECM harness connector from the ECM for approximately 1 minute. Reinstall all of the ECM connectors and then attempt to clear codes with the scan tool.
⇒ If DTC P2610 resets after code clear, replace the ECM.
Hope this helps. :)
Dec 9, 2007 at 6:03 AM
