Weird popping noise coming from my passenger side of my car
160,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MARBLCK86
  • 19 POSTS
Yes, I have replaced my struts,inner and outer tie rods, sway bar link, and lower control arms and ball joints both sides. And today I replaced my suspension knuckle assembly on my passenger side.i put brand new tires on it and also got it aligned.
Now I still have this weird popping noise coming from my passenger side of my car every time I hit a bump, and i cannot for the like of me find the problem. does any one have any information that could possibly help me out?
Aug 14, 2019 at 11:19 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a quick question first. Did you replace the strut as a complete unit or did you disassemble and just replace the cartridge? Thanks for using 2CarPros.
Danny-
Aug 14, 2019 at 12:22 PM
MARBLCK86
  • 19 POSTS
I replaced it all as one, referred to as a quick strut and the noise it makes is like when a strut or sway bar link is bad. but like I said i have replaced those as well every thing except for the rack and pinion. The CV axle is brand new. I didn't replace those yet or my sway bar bushings.
Aug 14, 2019 at 12:52 PM
  • 110,248 POSTS
Welcome to 2CarPros.
There are several technical service bulletins regarding a popping sound. Here is the one that seems to fit best with your description. Now, a number of these things have already been replaced. However, there are different components which have been revised based on build dates. Take a look through this TSB and let us know if any of it helps.
The attached picture is a list of part numbers.
2008 Ford Focus L4-2.0L
Suspension - Front End Pop/Click Noise On Bumps
Vehicle Steering and Suspension Suspension Stabilizer Bar Stabilizer Link Technical Service Bulletins By Symptom Suspension - Front End Pop/Click Noise On Bumps
SUSPENSION - FRONT END POP/CLICK NOISE ON BUMPS
TSB 10-8-5
CLICK/POP NOISE FROM FRONT END WHILE TURNING OR GOING OVER BUMPS
FORD:
2008-2010 Focus
This article supersedes TSB 09-18-2 to update the Service Procedure, Service Labor Time Standards and Part List.
ISSUE
Some 2008-2010 Focus vehicles may exhibit a click/pop type noise from the front end while turning and/or driving over bumps, or a creak/squeak noise from front when driving over bumps. The noise may be isolated to front stabilizer bar end links, front upper strut bearing area, and/or lower control arm.
ACTION
Follow the service procedure to correct the condition.
SERVICE PROCEDURE
1.Install Chassis Ear J5P97202 in the Rotunda Technician Tool Program or equivalent to identify and isolate the source of the noise.
2.Drive the vehicle over moderate bumps and perform left and right turns.
a. If a click/pop noise is coming from front stabilizer bar end link(s), proceed to Step 3.
b. If a click/pop noise is from upper strut bearing area, go to Step 4.
c. If a creak/squeak type noise is coming from a lower control arm, go to Step 5.
3.Front stabilizer bar end link click/pop noise.
a. Is vehicle built on or before 1/11/2010?
(1)Yes - remove and install four (4) revised stabilizer bar end link nuts per Workshop Manual (WSM), Section 204-01; torque to 46 lb-ft (63 N.m).
(2)No - replace affected stabilizer bar end link(s) per WSM, Section 204-01; torque nuts to 46 lb-ft (63 N.m).
4.Upper strut bearing click/pop noise.
a. Is vehicle built on or between 10/01/2007 and 10/31/2007?
(1)Yes - replace upper strut bearing per WSM, Section 204-01; torque nuts to 30 lb-ft (40 N.m).
(2)No - proceed to Step 3b.
b. Is vehicle built on or before 11/30/2008?
(1)Yes - inspect the three (3) upper strut mount nuts for signs of looseness. Torque nuts to 30 lb-ft (40 N.m).
(2)No - replace suspect strut per WSM, Section 204-01; torque upper nuts to 30 lb-ft (40 N.m).
5.Lower control arm creak/squeak noise.
a. Replace the affected lower control arm per WSM, Section 204-01.
pic 1
____________________
Aug 15, 2019 at 3:06 PM
MARBLCK86
  • 19 POSTS
Can a CV axle cause a popping noise when hitting bumps only?
Aug 15, 2019 at 10:56 PM
  • 110,248 POSTS
Welcome back:
Honestly, I wouldn't think so. Did you replace the sway bar bushings? I have actually seen the sway bar (not the link) crack under the bushing. See the two pictures I attached and let me know.
Aug 16, 2019 at 12:15 PM
MARBLCK86
  • 19 POSTS
No, I haven't, thank you. I'll check because you know what it could possibly be that. 4 days after we got the car done dummy slammed on her brakes and my girl ended up rear ending her a little bit only dented my bumper. But I'll check there. thanks
Aug 16, 2019 at 12:54 PM
  • 110,248 POSTS
Welcome back:
Glad to help. Let me know what you find.
Take care and good luck.
Aug 16, 2019 at 1:15 PM
MARBLCK86
  • 19 POSTS
I will do that, thanks again.
Aug 16, 2019 at 10:52 PM
  • 110,248 POSTS
Happy to help.
Aug 17, 2019 at 9:54 AM
ANGEL_GIRL
  • 8 POSTS
A couple of weeks ago I took my vehicle to a place to have new tires put on the back only. After that, when I drove the car it started making a popping noise. When I turn the wheels, while driving, or while I am sitting still it pops. It also pulls to the left or right side really bad while driving and then other times it drives straight. I have already replaced the bars coming from the shocks going to the sway bar. I am at my witts end please help! Thanks for all the help.
Aug 19, 2019 at 11:45 AM (Merged)
RIVERMIKERAT
  • 6,106 POSTS
Check the steering rack for play. Make sure all of the bolts in the suspension are tight.
ANGEL_GIRL
  • 8 POSTS
How would I check the steering rack for play?
  • 31,937 POSTS
Rock the steering back and forth with the engine of, have someone watch all steering components for any signs of wear or loose fitting components, if in doubt get a mechanic to check this for you, it will just take a few minutes.
HATJOHNSON
while driving I heard a loud pop and I was able to start my car, but was not able to move the car.
  • 31,937 POSTS
Check for a failed front drive shaft, check for torn CV boots as this can be a sign of a failed CV causing no drive.
HATJOHNSON
thank you I just got the answer, please dis regard my last email, CV shaft it is very expensive to repair and the car is 13 years old is it worth it. Thanks again Hattie Johnson
  • 31,937 POSTS
Reco change over units are not that expensive and about 1 hr labour so go get a quote first.
HATJOHNSON
Again thanks so much, I did find someone to do the job, I will be having it done tomorrow.
I just wanted to say thanks again.
SKIBOY78
I have a 2002 ford focus ZTS ZETEC engine with 78,000 miles on it. Recently I have this weird popping/clicking noise that has developed. It sounds very similar to the noise you get after you turn off the car and your car is cooling down. I figured out that the noise is really only prominent when the car is in gear and at idle. I had the belts checked and Brakes Plus stills says that they are fine. The noise is really only prominent when the car is in gear and at idle. I found a video that seems to have the same noise. It isn't the clicking noise that is constant, it is the little pop or crack that the engine makes about every half second to a second. http://www.youtube.com/watch?v=ci1c99n_Ldg
HMAC300
  • 48,601 POSTS
check for a vacuum leak and clean throttle plate on both sides with choke cleaner. have a local pro check for a bad cam/follower
  • 31,937 POSTS
OK, thank you for using 2carpros, good luck with this.......
MARBLCK86
  • 19 POSTS
So I checked my sway bar and nothing, I'm stumped and other suggestions?
Aug 20, 2019 at 1:14 PM
  • 110,248 POSTS
Welcome back:
Wow! You have done everything. I am going to ask the site owner for his opinion. He is an excellent tech, so maybe he can think of something that I'm missing. If you see a reply from Ken, that's him. I will stay in the loop also.
Aug 20, 2019 at 1:36 PM
MARBLCK86
  • 19 POSTS
Ok thank you very much
Aug 20, 2019 at 1:40 PM
  • 55,721 POSTS
I have seen these cars have body pops which can occur where the strut is mounted. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Aug 21, 2019 at 11:19 AM
MARBLCK86
  • 19 POSTS
I will do that it might be tomorrow though.
Aug 21, 2019 at 11:47 AM
  • 55,721 POSTS
That would be great that way we will know better on how to fix it. Thank you.
Aug 21, 2019 at 11:56 AM
MARBLCK86
  • 19 POSTS
No problem. thank you
Aug 21, 2019 at 11:57 AM
MARBLCK86
  • 19 POSTS
Now I do know if you can really hear the noise but it's on this video, I did a little research and came across this one. boy that was having the same issue with his truck, and found out that it could be the CV axle.
Aug 24, 2019 at 10:53 PM
MARBLCK86
  • 19 POSTS
It is just getting worse. now I feel like I have a little bit of a grinding noise or some sort of friction. I wiggled my CV axle and it was making a little noise kinda sounded like it was loose inside the joints of the CV axle, I do not know, I don't want to get rid of the car but I'm about to.
Aug 24, 2019 at 10:55 PM
MARBLCK86
  • 19 POSTS
If this could help you out. also my car has around 168,000 miles on it the only parts I have not replaced are the CV axle, sway bar bushings and my rack and pinion.
Aug 25, 2019 at 12:21 AM
  • 110,248 POSTS
Welcome back:
I listened to the video. It sounds like something that is turning making the noise. It could be one of the joints in the axle or even a wheel bearing. Is there any humming when driving or clicking when turning?
Take a look through this link:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Let us know.
Aug 25, 2019 at 1:10 PM
MARBLCK86
  • 19 POSTS
No no humming at all I replaced my suspension knuckle assembly.. that's why I thought it was a CV axle.
Aug 25, 2019 at 10:31 PM
MARBLCK86
  • 19 POSTS
Sorry, and there's no clicking at all.
Aug 25, 2019 at 10:32 PM
MARBLCK86
  • 19 POSTS
Okay, so I just bought me a new CV axle I'm going to put it in tomorrow and hopefully that takes care of the issue. I will update with you guys.
Aug 26, 2019 at 12:38 AM
MARBLCK86
  • 19 POSTS
And another question what is the correct suspension torque for the 2008 Ford focus se? And the torque for the CV axle as well
Aug 26, 2019 at 2:57 AM
  • 55,721 POSTS
What part of the suspension? Can you shoot a picture?
Aug 26, 2019 at 5:33 AM
MARBLCK86
  • 19 POSTS
I'll get you all the pictures tomorrow of it.
Aug 26, 2019 at 9:17 AM
MARBLCK86
  • 19 POSTS
Well, I replaced my CV axle and went through my torque on everything and well it took care of my nose issue. thanks guys
Aug 27, 2019 at 8:51 AM
  • 110,248 POSTS
Welcome back:
I'm glad you got it fixed. Let us know if we can help in the future.
Aug 27, 2019 at 12:51 PM
