So i just did a transmission swap in my vehicle, but the transmission i swapped came from a 1994 Bronco. It drives great, but occasionally and randomly, my engine light turns on and my overdrive light blinks. The only code that pops up is a transmission pressure code. what should i do?
My Bronco is a 1996 with OBD2. The Bronco that it came from was a 1994 with obd1. Do i need to redo the wire harness? should i go back to the 1994 Bronco and grab the computer? Help!
Dec 20, 2019 at 12:53 PM
