DEREK
1989 Ford Bronco 5.0 Engine Swap Options
DEREK
The switch would be tricky though. You have a EEC-IV fuel injection system which is OBD-I emissions. An older car (such as a torino or older mustang) would need all that junk with the engine to run well, unless you converted it to a carb and duraspark system.
If you wanted to stick with the fuel injection, at the very least you would have to switch out the truck intake and top end system, and put in place a car intake and top end because of hood clearance issues.
Basically you won't be able to just take the engine out and drop it right into a car. Things will have to changed around and tweaked. But they are good engines, and pretty versatile. So many companies make all kinds of conversion kits for all kinds of cars.
Suggested Repair
The 5.0 will not drop directly into a car. Older full-size Ford, Lincoln, or Mercury cars are the most practical recipients; smaller cars such as Taurus, Sable, Contour, and Escort are not. Keep the EEC-IV fuel-injection system with the engine, or convert it to a carburetor and Duraspark setup. For fuel injection, replace the truck intake and top end with a car setup for hood clearance, and expect additional fitment work or a conversion kit.
Conversation Summary
The owner of a 1989 Ford Bronco XLT with a healthy 302 5.0 and five-speed manual wants to install the engine in a car. The expert says older full-size Ford, Lincoln, and Mercury cars can accept a 5.0, while smaller Ford cars cannot. The swap requires electronics, intake, and clearance changes rather than a direct installation, although conversion kits are available.
