clutch problems
TINKLEISGOOD78
hi, i have a 1987 ford bronco . the motor has 15,000miles and a new clutch both put in last year. when i press the clutch down i cant put the truck into gear . PLZ help me troubleshoot this !!
Jun 2, 2006 at 7:02 PM
LEAHMG1988
i have the same problem, my clutuch went floppy and i cudnt put my gear in. someone said it was the clutch cable? have u has that checkd, mines in da garage so i dnt know my problem yet x
Aug 8, 2006 at 7:24 AM
SYNCRAIT
  • 235 POSTS
im not sure what type of clutch system is on that particular model but its pretty obvious once you start doing some hunting around look for either a cable that pulls on a lever mounted to the side of the gear box or a hydraulic line attached to a cylinder mounted to the side of the gear box........can you put your truck in gear without the truck running and not using the clutch you might need to rock the truck to do so...... lemme know.... good luck :)
Aug 8, 2006 at 7:29 AM
