transmission problem, only drives in limp mode?
2002 MERCEDES BENZ E320
100,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
BERNIE GARRISON
  • 5 POSTS
it only drives in limp mode max speed is 30 MPH.
Feb 5, 2023 at 3:45 AM
  • 110,241 POSTS
Because of the complexity of this vehicle, I recommend having the can-bus scanned because many things can cause the vehicle to be in limp mode. CAN stands for controller area network.
Basically, all the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that shows how it's done:
That is where I would start. However, I don't know if you have already tried this or had the computer scanned. If you have, let me know if there are codes stored or anything that you feel may be helpful for me.
Feb 5, 2023 at 8:51 AM
