Transmission shifting issue
111,000 MILES • 2.0L • 4 CYL • AUTOMATIC
SHUTESPRIDE
Shifts fine from first to second gear but then no third or fourth gear.
Aug 12, 2019 at 11:09 PM
94 TRANSAM
  • 680 POSTS
Hi and thank you for using 2CaPros
This is likely 1 of 2 things.
1. Your third gear clutch pack is worn out. If you can't get third you wont get fourth. This is very likely given the mileage. The fix is a transmission overhaul.
2. Your third gear shift solenoid has failed. And again, no third then no fourth.
A transmission shop can test and confirm either one.
If you have anymore questions please ask. If you do take it to a shop let us know what they say.
Thank you, Rich
Aug 13, 2019 at 3:15 PM
