2005 Hyundai Elantra Torque Specs
2005 HYUNDAI ELANTRA
ITACHI875
Engine Mechanical problem
2005 Hyundai Elantra 4 cyl Two Wheel Drive Automatic
i need torque specs for the main bearings and connecting rod please.
Mar 2, 2010 at 9:49 AM
  • 55,423 POSTS
Hey ITACHI875,
Got all the torque specification you need. The last two numbers are foot pounds
Item Nm kgf.cm lbf.ft
Cylinder Block
Front engine support bracket bolt and nut 35 ~ 50 350 ~ 500 25 ~ 37
Front roll stopper bracket bolt 70 ~ 90 700 ~ 900 51 ~ 65
Rear roll stopper bracket bolt 70 ~ 90 700 ~ 900 51 ~ 65
Rear engine stopper bracket bolt 35 ~ 50 350 ~ 500 25 ~ 37
Engine Mounting
Right mounting insulator (large) nut 90 ~ 110 900 ~ 1100 65 ~ 80
Right mounting insulator (small) nut 45 ~ 60 450 ~ 600 33 ~ 44
Right mounting bracket to engine nuts and bolts 50 ~ 65 500 ~ 650 36 ~ 48
Transmission mount insulator nut 90 ~ 110 900 ~ 1100 65 ~ 80
Transmission insulator bracket to side member bolt 40 ~ 50 400 ~ 500 30 ~ 36
Rear roll stopper insulator nut 50 ~ 65 500 ~ 650 36 ~ 48
Rear roll stopper bracket to center member bolts 40 ~ 50 400 ~ 500 30 ~ 36
Front roll stopper insulator nut 50 ~ 65 500 ~ 650 36 ~ 48
Front roll stopper bracket to center member bolts. 40 ~ 50 400 ~ 500 30 ~ 36
Main Moving
Connecting rod cap nut 50 ~ 53 500 ~ 530 36 ~ 39
Crankshaft bearing cap bolt 27~33 + (60°~65°) 270~330 + (60°~65°) 20~24 + (60°~65°)
Fly wheel M/T bolt 120 ~ 130 1200 ~ 1300 88 ~ 95
Drive plate A/T bolt 120 ~ 130 1200 ~ 1300 88 ~ 95
Engine cover 4~6 40 ~ 60 3~4
Heat protector 15 ~ 20 150 ~ 200 11 ~ 15
Water pipe bracket bolts 12 ~ 15 120 ~ 150 9 ~ 11
Cooling system
Alternator support bolt and nut 20 ~ 25 200 ~ 250 14 ~ 18
Alternator lock bolt 12 ~ 15 120 ~ 150 9 ~ 11
Alternator brace mounting bolt 20 ~ 27 200 ~ 270 15 ~ 20
Coolant pump pulley bolts 8 ~ 10 80 ~ 100 6 ~ 7
Coolant pump bolts 20 ~ 27 200 ~ 270 14 ~ 19
Coolant temperature sensor 20 ~ 40 200 ~ 400 15 ~ 30
Coolant inlet fitting nuts 15 ~ 20 150 ~ 200 11 ~ 14
Thermostat housing bolts and nuts 15 ~ 20 150 ~ 200 11 ~ 14
Lubrication system
Oil filter 12 ~ 16 120 ~ 160 9 ~ 12
Oil pan bolts 10 ~ 12 100 ~ 120 7 ~ 9
Oil pan drain plug 40 ~ 45 400 ~ 450 30 ~ 33
Oil screen bolts 15 ~ 22 150 ~ 220 11 ~ 16
Oil pressure switch 13 ~ 15 130 ~ 150 9.7 ~ 11
Intake and Exhaust system
Air cleaner body mounting bolts 8~ 10 80 ~ 100 6 ~ 7
Resonator mounting bolts 4 ~ 6 40 ~ 60 3 ~ 4
Intake manifold to cylinder head nuts and bolts 16 ~ 23 160 ~ 230 12 ~ 17
Intake manifold stay to cylinder block bolts 18 ~ 25 180 ~ 250 13 ~ 18
Throttle body to surge tank nuts 15 ~ 20 150 ~ 200 11 ~ 14
Exhaust manifold to cylinder head nuts 43 ~ 55 430 ~ 550 32 ~ 40
Exhaust manifold cover to exhaust 15 ~ 20 150 ~ 200 11 ~ 14
manifold bolts
Oxygen sensor to front muffler 50 ~ 60 500 ~ 600 36 ~ 43
Oxygen sensor to exhaust manifold 50 ~ 60 500 ~ 600 36 ~ 43
Front exhaust pipe to exhaust manifold nuts 30 ~ 40 300 ~ 400 22 ~ 29
Front exhaust pipe bracket bolts 30 ~ 40 300 ~ 400 22 ~ 29
Front exhaust pipe to catalytic converter bolts 40 ~ 60 400 ~ 600 29 ~ 43
Main muffler hanger support bracket bolts 10 ~ 15 100 ~ 150 7 ~ 11
Cylinder head
Cylinder head bolts - M10 25 + (60°~65°) + (60°~65°) 250 + (60°~65°) + (60°~65°) 18 + (60°~65°) + (60°~65°)
Cylinder head bolts - M12 30 + (60°~65°) + (60°~65°) 300 + (60°~65°) + (60°~65°) 22 + (60°~65°) + (60°~65°)
Intake manifold nuts 18 ~ 25 180 ~ 250 13 ~ 18
Exhaust manifold nuts 43 ~ 55 430 ~ 550 32 ~ 41
Cylinder head cover bolts 8 ~ 10 80 ~ 100 6 ~ 7
Camshaft bearing cap bolts 14 ~ 15 140 ~ 150 10 ~ 11
Oil control valve bolt 10 ~ 12 100 ~ 120 7.3 ~ 8.8
OCV Filter 41 ~ 51 410 ~ 510 30 ~ 37.6
CVVT unit to exhaust camshaft bolt 66 ~ 78 660 ~ 780 48.7 ~ 57.5
Rear plate bolts 8 ~ 10 80 ~ 100 6 ~ 7
Timing Belt
Crankshaft pulley bolt 170 ~ 180 1700 ~ 1800 125 ~ 133
Camshaft sprocket bolt 100 ~ 120 1000 ~ 1200 74 ~ 89
Timing belt tensioner bolts 43 ~ 550 430 ~ 550 31 ~ 40
Timing belt cover bolts 8 ~ 10 80 ~ 100 6 ~ 7
Front case bolts 20 ~ 27 200 ~ 270 14 ~ 20
Timing belt idler bolt 43 ~ 55 430 ~ 550
Please let us know happens so it will help others.
Best, Ken
Dec 22, 2016 at 8:03 AM
