HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL1
Drivetrain
Transmission
Valve Body
Replace/Remove
Transmission hard shifting
PREV
1
2
NEXT
MECHANIC
Yes, you need a scanner that can communicate with the modules. Sorry, I'm not sure what type of scanner you have. If it can only retrieve codes, it won't work.
Thursday, March 31st, 2022 AT 1:26 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Transmission Valve Body Replace/Remove Content
Replaced Valve Body Still Had Hard Shift - Replaced...
Had Hard Shifts Replaced The Valve Body - Replaced Trs Lp Fuse That Was Blown Now It Will Not Shift At All.
Asked by
mike G
2 IMAGES
2001
SATURN SL1
2002 Saturn Sl1 02 Saturn Sl1 No 4th Gear
I Have An 02 Sl1. When I Purchased It The Car Had The Reverse Slam, Hard Shifts And No 4th Gear. I Changed The Pressure Control Solenoid...
Asked by
satren2002
2 IMAGES
2002
SATURN SL1
Bought April 2011 With 11000 Miles. Automatic...
Bought April 2011 With 11000 Miles. Automatic Transmission Slip In 2d Gear (25 Mi/hr) Just Once When Cold. Began Fall 2011 And All Winter...
Asked by
Patrice9
1 ANSWER
2002
SATURN SL1
1999 Saturn Sl1 Transmission Cost
How Much Would It Cost To Either Rebuild The Transmission, Or Put In A New Transmission, On A 99 Saturn Sl1?
Asked by
dlmnf4
1999
SATURN SL1
1999 Saturn Sl1 Jerking When Put In Reverse
I Just Purchased A Saturn Sl1 And The Car Seems To Jerk When Putting It In Reverse What Could Be Wrong.
Asked by
lbrandon
1 ANSWER
1999
SATURN SL1
VIEW MORE
Code Read Retrieval/Clear - Dodge Stratus
What to Do When a Check Engine Light?
How to Read Trouble Codes
