I just purchased a Saturn SL1 and the car seems to jerk when putting it in reverse what could be wrong.
Monday, September 20th, 2010 AT 5:11 PM
SATURNTECH9
MECHANIC
Most likely you need a valve body and you possibly have a loose input shaft nut. But without some test's checking the transmission fluid pressure and air checking the clutches also check for code's. To figure out what you need or you have bigger problem's.
