Transmission not shifting correctly?
RCGYGI
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 181,000 MILES
My friends accord started shifting hard and now doesn't want to shift. The fluid level is good and the fluid doesn't seem to be burnt. I'm a shade tree mechanic and I know some automatics need to be put on a machine and drained so there is no air introduced into the system, is this a fact with the honda? Or, can I change the filter myself like I have done to other models?
Saturday, September 26th, 2020 AT 11:25 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi rcgygi,
Firstly this transmission is equipped with a maintenance free strainer and there is no filter to be replaced. For replacement you need to strip the transmission.
Secondly for fluids, you top it up and drive, there are no such thing as air in system. The running of the pumps would clear all the air in system, unless it is overfilled when churning occurs and bubbles are introduced into the pump or if the level is too low and air is sucked up by the pump.
Thirdly, when the transmission fails to shift, you need to check the symptoms.
Does it move in reverse?
Any gears that is working?
Have you tried to retrieve for trouble codes?
SAEED AHMED
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 63,000 MILES
Recently I changed the ATF of my car and it started thudding and sliping the gears while shifting. These problems were never experienced before in the car. Kindly advise me how to tackle.
KHLOW2008
  • 41,814 POSTS
Hi Saeed Ahmed,
Is the fluid level correct?
Was the fluid used of the correct specification?
MICHAEL 11
  • 1998 HONDA ACCORD
  • 4 CYL
  • 198,000 MILES
I assume the transmission may be defective but before I replace the transmission maaybe the problem might be electrical ecu/trabnsmission ecu or some other sensor.
The transmission will onlly change into second gear, sometimes to third gear and down shifts quickly at times.
What do you think I should do first to diagnos.
Thanks mike
KHLOW2008
  • 41,814 POSTS
Hi michael 11,
The first thing you need to do is retrieve for trouble codes. Let me know the exact code if any found.
Autozone provides free scanning services.
ACCORD_BOI
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 168,000 MILES
About a few weeks back I was going up MontEagle Mountain in my car when I noticed that it wouldn't hardly pull itself up the hill. I stopped at a store and turned my car off to let it rest for a second and checked the trans fluid it was fine. When I continued on my trip the car run fine for about another hour, then I noticed that the car started to have problems staying in gear for example I would lose D4 then I would shift into D3 and it worked for a while and then it started doing the same thing in that gear. I stopped again and let it rest for a few more minutes and it run fine again. It kept this pattern for a few days and I finally had someone come scan it they said it showed three different codes P0730, P0740, and P0138 I believe this is right that last one was I know that they said one was the gear ratio anyways they reset the codes and the car run fine for about 10 minutes and then started slipping again. I have not touched it since until today when I decided to drive it and it run fine for about 30 minutes with me having to only turn it off once in that time and then it run fine again. Could it be a lock up shift solenoid? Or if you have any suggestions of what it might be that would be great because I have been told that I need a new transmission but have also been told I do not. Any advice would be great thanks!
NDMAND
  • 5 POSTS
Same Problem,
My Accord started having a very simialr problem on Friday. Mine is a little less controllable. I've found that if I press the accelerator and rev it up, it will up shift to the proper gear for while before shifting down again. I am taking mine to the shop tomorrow. If I learn anything, I will try to post here. Please post again if you learn anything.
Thanks, Ndmad
