When transmission is shifted into any gear it will not accelerate at all
90,049 MILES • 3.4L • V6 • 2WD • AUTOMATIC
REGGY IRVAN
Vehicle will not accelerate, will not move. I'm putting part versus neutral it won't even neutral, drive, it won't move. first second and will not move at all. man I don't replace the solenoids. I'm really leaning on sports acceleration sensors and stuff like that I need to know what to do next.
Sep 27, 2020 at 12:09 PM
Good morning,
Did you change the fluid and filter in the transmission? If the filter is clogged it will do this.
Beyond that, the issue is most likely internal such as the front pump or the torque converter.
It is not a solenoid as engagement is mechanical, not electrical.
Sep 27, 2020 at 7:21 PM
