Will not accelerate
160,000 MILES • AWD • AUTOMATIC
BASH69
Recently and now, my car will accelerate until thirty mph then it will stop accelerating and loud thumping comes from the rear. Sometimes it will go back to normal. But I have had to pull over on the interstate and turn my car off then it will be okay again. What does this sound like? I have had issues with the wiring of my all wheel drive and the light is currently on but it has been for awhile with no issues. I have noticed no leaks but my fuel line seems to expel a lot cause I can smell it.
May 7, 2017 at 3:11 AM
  • 55,857 POSTS
I want to help you here but Im not sure where to start. Does it feel like the brakes are coming on or the engine is having a hard time, do you have a check engine light on or does it seem like an exhaust system issue?
Best, Ken
May 9, 2017 at 5:07 AM
BASH69
Thanks for the reply! Yes the check engine light is also on. Since it was repaired I have noticed that the brakes tighten up sometimes when I drive or try to brake but it still always me to brake. I took it to the shop and they said nothing was was show on the analysis. They said it may be the computer in the engine but they aren't sure. They checked just about everything. The thumping in the rear is new ( when it wouldn't accelerate passed 30 mph)
May 10, 2017 at 4:53 AM
  • 55,857 POSTS
If the check engine light is on we need to start by checking the codes here is a guide to help you get the job done.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
May 10, 2017 at 7:54 AM
BASH69
That's the thing, they said they looked into that and no codes were shown. Can that even happen?
May 10, 2017 at 10:02 AM
  • 55,857 POSTS
If the check engine light is on there should be codes, have them rerun the test.
May 11, 2017 at 3:59 AM
