Trac control
TUB TUB
  • 2000 PONTIAC GRAND PRIX
  • 170,000 MILES
So when I get the car up to 70 mph and 3000 rpms the car starts to miss like its running out of gas then if u press the trac control button it stops when trac control is turned off also it rides like it has a flat front pass tire its not flat and air pressure is good we replaced the racn pinion to fix some issues along with the axles any input would be good considering im about to strick a match and watch it burn
Monday, May 20th, 2013 AT 8:26 AM
WRENCHTECH
  • 20,761 POSTS
Check all your tires carefully looking for a deformity when spinning. You could have electronic issues with the speed sensors but the computer should be picking up on something like that.
Monday, May 20th, 2013 AT 9:00 AM
