1992 Toyota Tercel Warm Stall
THOMASRR
I have a 92 toyota tercel auto, 113k 1.5 liter when the engine is warm it sometimes does not want to start without idleing rough or stalling until I hit the gas what could cause this? when on runs fine and has no problem at all thanks. :(
Jan 24, 2007 at 3:48 AM
  • 75,988 POSTS
[quote:dbbb979ca6="thomasrr"]I have a 92 toyota tercel auto, 113k 1.5 liter when the engine is warm it sometimes does not want to start without idleing rough or stalling until I hit the gas what could cause this? when on runs fine and has no problem at all thanks. :([/quote:dbbb979ca6]
Inspect and test the coolant temperature sensor,IACV,and MAF sensor
Jan 24, 2007 at 7:35 AM
Suggested Repair
Inspect and test the coolant temperature sensor, idle air control valve (IACV), and MAF sensor.
Conversation Summary
The owner of a 1992 Toyota Tercel automatic with a 1.5L engine and 113,000 miles says that when the engine is warm it sometimes will not start without idling roughly or stalling until the accelerator is pressed. Once running, it drives fine. The expert advises inspecting and testing the coolant temperature sensor, IACV, and MAF sensor.
