1992 Toyota Tercel car wont start
BBEN10131989
  • 1992 TOYOTA TERCEL
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
I shut my toyota tercel off yesterday and went back to start it and it wouldnt start. I changed the battery today and it cranks over but it wont start
Friday, February 26th, 2010 AT 11:28 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, February 26th, 2010 AT 3:14 PM
