Heater and defroster issues
NETTERZ
My boyfriend has a 1991 Toyota Tercel that he got from his sisters boyfriend who had apparently treated it kinda bad. . My concern now is the heater and defroster. We cant seem to keep the windows from fogging up at all and keeping the inside of the car warm is nearly impossible because the heater gives of very little heat and the heat that should come out of the vents directly under the windshield doesnt. An the heater itself makes a loud buzing noise. My question is what do we replace? Right now Im thinking that replacing the whole works would be best but any suggestions that could save us some money would be great.
Oct 17, 2007 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
the blending door in the dash may not be functioning properly due to bad vaccum or bad lines. can you hear the door moving in there? if not then you probably need to check the lines going ot it.
Oct 19, 2007 at 3:37 AM
