1993 Toyota Tercel Stalls at Idle
4EYEDHOOSIER
My daughter has a 1993 toyota tercel, mileage is 134,000, it is a 4 cylinder, in line, 4 cycle. after driving a few minutes, when she comes to a stop, or slows way down, it will idle real low, and stall. it'll crank but will not fire until 5 or 10 minutes have elapsed. we changed the plugs, plug wires, and distributor. any ideas? thanks much.
Aug 26, 2007 at 6:52 AM
  • 75,988 POSTS
[quote:39686329d8="4eyedhoosier"]My daughter has a 1993 toyota tercel, mileage is 134,000, it is a 4 cylinder, in line, 4 cycle. after driving a few minutes, when she comes to a stop, or slows way down, it will idle real low, and stall. it'll crank but will not fire until 5 or 10 minutes have elapsed. we changed the plugs, plug wires, and distributor. any ideas? thanks much.[/quote:39686329d8]
Check the EGR valve and its VSV solenoid whether its getting vacuum and transferring it to the EGR.
Aug 26, 2007 at 10:56 AM
Suggested Repair
Check the EGR valve and its VSV solenoid to confirm vacuum is present and is being transferred to the EGR valve.
Conversation Summary
A 1993 Toyota Tercel with 134,000 miles idles very low and stalls after a few minutes of driving when stopping or slowing down. It cranks but will not restart for 5 to 10 minutes. Plugs, plug wires, and the distributor were already replaced. The expert recommends checking the EGR valve and VSV solenoid for vacuum supply and transfer to the EGR.
