1994 Toyota Tercel Dies After High Rev
POOLCHICK98198
i am trying to determine the reason my tercel died.
I was driving down the road and as i down shifted to come to a stop, the engine revved high and then stopped. I took it to a mechanic and had a cursory look taken, they said it was not the timing chain or aniything that they could identify.
I bought the car with a rebuilt engine and transmission.
It is a 1994 Toyota Tercel STD, has approx. 151K miles and is a manual transmission. i believe that it has a 3.0 4 cylinder engine, which is the standard engine for this model.
when i get in to start it the starter cranks but nothing happens. the alternator has also been tested and there is nothing wrong with that either.
What other problems could cause the engine to rev high and then just die?
Feb 12, 2007 at 7:46 AM
  • 75,988 POSTS
Have the EFI system check
Feb 12, 2007 at 12:10 PM
CAVALIERDRIVER65
  • 31 POSTS
i had a 1993 toyota tercel and with the cranking problem, check for spark and if no spark occurs, you need a new distributor.
Mar 4, 2007 at 2:44 AM
Suggested Repair
Have the EFI system checked. Also check for spark while cranking; if there is no spark, the distributor may need to be replaced.
Conversation Summary
A 1994 Toyota Tercel with a manual transmission and about 151,000 miles revved high while downshifting, then died and would not restart. The starter cranks, the alternator tested fine, and a mechanic did not find a timing-chain problem. Suggestions were to check the EFI system and test for spark, replacing the distributor if no spark is present.
