Thanks
1992 Toyota Tercel Blue White Smoke
Thanks
Suggested Repair
Treat blue smoke and rapid oil use as oil burning, possibly from valve guide seals, and white smoke or radiator smoking as a coolant leak, commonly a head gasket. Confirm which fluid is being burned before further repairs, since plugs fouling every few months fits oil entering the cylinders.
Conversation Summary
The owner of a 1992 Toyota Tercel reported blue/white smoke at startup and after idling, rapid oil use, and spark plugs that needed replacement every few months. A friend suspected valve guide seals. The expert said blue smoke indicates oil and could be valve seals, while white smoke usually indicates coolant and a head gasket. A later comment described extensive head, exhaust-valve, and related work on a similar Tercel, continued heavy oil use, more consistent smoking, and radiator smoking.
