1993 Toyota Tercel Black Smoke
TXIKI
  • 5 POSTS
Hi:
My buddy is selling me his car for 500$, it is aTercel 93, 121.000 miles and when you press on the gas smoke comes out, what can be the problem? Will you buy it? The outside of the car it is almost in perfect condition. Thanks
Jan 12, 2007 at 10:45 AM
  • 75,988 POSTS
[quote:e4fe394dc5="txiki"]Hi:
My buddy is selling me his car for 500$, it is aTercel 93, 121.000 miles and when you press on the gas smoke comes out, what can be the problem? Will you buy it? The outside of the car it is almost in perfect condition. Thanks[/quote:e4fe394dc5]
Depends what kind of smoke coming out of the rear.
we need to know the color of the smoke before we can help.
Jan 12, 2007 at 10:04 PM
TXIKI
  • 5 POSTS
The smoke is black, thanks
Jan 12, 2007 at 11:37 PM
SERVICE WRITER
  • 9,123 POSTS
This indicates that it is burning more fuel than it should. May be as simple as a bad oxygen sensor.
Jan 13, 2007 at 12:46 AM
TXIKI
  • 5 POSTS
Thank you very much, so if that is the problem should I get the car for that price?(500$)
Jan 13, 2007 at 12:54 AM
SERVICE WRITER
  • 9,123 POSTS
My opinion is to take it to a garage that you normally deal with and ask them to look it over. It may be $50 or whatever, but may reveal a potential scary needed repair. I have often found that the owner doesn't realize a problem exists and honestly believes there isn't when selling it. My experience shows that when you spend less than a thousand you need to spend another thousand of unexpected things pretty quick. Still that is cheap. Just like this forum is inexpensive, a small donation shows our donated time is appreciated :wink:
Depending on the area of the country you are located can make a difference. Here in
Niagara Falls,NY Road salt eats up cars and renders them unrepairable eventually. Not many 93's are in great shape up here, but that isn't everthing. I have a customer with an 82 pontiac that most people would have given up on. So have it looked it first. :)
Jan 13, 2007 at 1:13 AM
TXIKI
  • 5 POSTS
I will do that, I'm in Ma and looking for an economic car, I have a Ram 2001 and it is killing me with the gas, fuel pumps and brakes. Thanks
Jan 13, 2007 at 1:18 AM
Suggested Repair
Have a trusted garage inspect the car before purchase. Black smoke under acceleration indicates a rich fuel mixture; a faulty oxygen sensor is one possible cause, but other fuel-system problems may be present.
Conversation Summary
A buyer is considering a 1993 Toyota Tercel with 121,000 miles priced at $500 that smokes when the accelerator is pressed. The smoke is black, which an expert says indicates excess fuel is being burned and may be as simple as a bad oxygen sensor. The expert recommends a pre-purchase inspection because inexpensive cars often need additional unexpected repairs.
