1993 Toyota Tercel No Acceleration
MECHJAGGER
1993 Toyota Tercel w/ 90,000 miles. Automatic, (2.2L engine, I think).
Had severe engine problems, pulled the engine replaced all gaskets, water pump, piston rings, etc. Engine runs great. However the car has no acceleration, at max the car can reach 15 mph with the petal all the way down. Engine seems to rev fine when in park, but when in drive doesn't, is very very delayed. Another odd thing the shifter wont go into Drive until after the car has been running for a few minutes. Fuild levels are fine, no leaking.
Any suggestions are appreicated.
Apr 16, 2007 at 6:10 AM
  • 75,988 POSTS
[quote:62a696d120="mechjagger"]1993 Toyota Tercel w/ 90,000 miles. Automatic, (2.2L engine, I think).
Any suggestions are appreicated.[/quote:62a696d120]
Check the CTS, TPS, VSS these checks out-could be the tranny slipping
Apr 16, 2007 at 8:59 AM
MECHJAGGER
CTS, VSS, TPS, and MAP all tested fine. Also I'm hoping I've got the hoses on right, this car uses an Auxiliary Air Value on the lower intake manifold. I can't find a hose reference anywhere. I only guessed the location the hoses go back on. Their are 4 ports, two are golden colored, and two gray, I assumed the gray ones are for the radiator pump. The other two split and goto the power steering cylinder and VSS. Disconnecting these doesn't appear to make any difference in the opperation of the engine though.
Could this be a problem with the torque converter posibly not being filled with fluid? I had removed the torque converter but did nothing to the transmission other than disconnect hoses.
May 16, 2007 at 7:30 AM
  • 75,988 POSTS
[quote:31220ec200="mechjagger"]CTS, VSS, TPS, and MAP all tested fine. Also I'm hoping I've got the hoses on right, this car uses an Auxiliary Air Value on the lower intake manifold. I can't find a hose reference anywhere. I only guessed the location the hoses go back on. Their are 4 ports, two are golden colored, and two gray, I assumed the gray ones are for the radiator pump. The other two split and goto the power steering cylinder and VSS. Disconnecting these doesn't appear to make any difference in the opperation of the engine though.
Could this be a problem with the torque converter posibly not being filled with fluid? I had removed the torque converter but did nothing to the transmission other than disconnect hoses.[/quote:31220ec200]
Check the exhaust system for restriction
May 16, 2007 at 10:14 AM
Suggested Repair
With CTS, TPS, VSS, and MAP testing fine, check the exhaust system for restriction. Also consider transmission slip or incomplete torque-converter fill after the converter was removed and transmission hoses were disconnected.
Conversation Summary
A 1993 Toyota Tercel runs well after an engine rebuild but barely accelerates in Drive, topping out around 15 mph, while it revs normally in Park. The shifter also will not enter Drive until the car has run for a few minutes, and fluid level is normal with no leaks. The owner reported CTS, VSS, TPS, and MAP tests were fine and asked about guessed auxiliary-air-valve hose routing and whether the removed torque converter was not refilled. The expert first suggested those sensors and possible transmission slip, then recommended checking the exhaust for restriction.
