1994 Toyota Tercel Won't Crank
DGOTTSHALL
1994 Tercel, 102K, will not turn over. Plenty of juice to turn on lights and car runs fine if push started (standard transmission). I have tried all gears, neutral, clutch down etc...Is there a safety switch that goes bad?
Sep 19, 2007 at 10:33 PM
SERVICE WRITER
  • 9,123 POSTS
IF you put it in neutral, and hot wire/jumper the starter, you'll eliminate the starter.
There is a neutral saftey switch, sometimes called a clutch switch that may be bad like you think, the parts store will know what you mean...may be a dealer part.
Sep 20, 2007 at 12:36 AM
Suggested Repair
With the transmission in neutral, jumper the starter to rule it out. Also check the clutch or neutral safety switch, which may be a dealer part.
Conversation Summary
A 1994 Toyota Tercel with 102,000 miles will not crank, although the lights work and it runs normally when push-started. The owner has tried different gears, neutral, and the clutch pedal and suspects a safety switch. The expert says jumpering the starter in neutral can eliminate the starter and that a faulty clutch or neutral safety switch is a likely cause.
