1991 Toyota Tercel Replacing head vs. engine?
1991 TOYOTA TERCEL
180,000 MILES • V12 • FWD • MANUAL
DEESQUIRRELDF
The top of my radiator cracked while I was driving. I cooled down engine for 30min. then drove 65mph for 6 miles. I drained oil pan and no antifreeze found. I drained radiator no oil found. I replaced my cracked radiator with a new one. When I poured in the antifreeze a leak started at the manifold gasket. (FYI: Entire exhaust replaced last month, manifold to tailpipe) I emptied the radiator. Pulled the spark plugs to find second plug wet and antifreeze leaking from only second cylinder. I'm going to have head checked but would it just be cheaper to replace the engine? I've already put alot in this vehicle and expect more but I want to do it right the first time. Thanks for your help. I've read alot of other posts that were helpful. Hopefully you'll be able to pin point an answer for me. Thanks again
Nov 4, 2009 at 5:17 AM
  • 31,937 POSTS
Hi there,
For the sake of removing the head and having it checked out first may safe some dollars, normally there is no problem with having the head repaired, the only draw back is if you do get the head fully re built you may experience some oil burning issues down the track, so it may be a good idea to get a leak down test done first to determine the viability of the lower end to accept a over hauled head, if there is any doubt go for the engine swap instead.
Mark (mhpautos)
Nov 4, 2009 at 8:48 AM
DEESQUIRRELDF
Thanks so much for your help. I've been reading all day. This site is amazing! Thanks :)
Nov 4, 2009 at 9:47 AM
  • 31,937 POSTS
Hi there, thank you for using 2carpros, we are striving to improve this site and your positive feed back is most welcome, feel free to re post if you need more advice or assistance.
Mark (mhpautos)
Nov 4, 2009 at 10:29 AM
