Head Gasket Replament
MARIO121
  • TOYOTA TERCEL
1997 Toyota Tercel 115,000 1.5
I got this car for free from my brother he new it needed a new head gasket I got it for my son. I have removed the head and had it machine. I have purchased a service manual for this car however, I need help in determining how to set the crankshaft relative to the crankshaft position sensor. Can I assume that if I put the crankshaft on the trimming marks as outline in the service manual, that I will have the crank shaft correctly set as far as the crankshaft position sensor is concerned? :Wink:
Thursday, October 25th, 2007 AT 5:42 PM
MERLIN2021
  • 17,250 POSTS
I think so, usually the camshaft sensor is the tricky one!
Thursday, October 25th, 2007 AT 6:00 PM
MARIO121
Once you set the crank, the camshaft sensor should be properly set assuming that timing belt is set correctly. Is this accurate?
Thursday, October 25th, 2007 AT 6:08 PM
MERLIN2021
  • 17,250 POSTS
I could look it up for you, but you forgot to give the engine size?
Thursday, October 25th, 2007 AT 6:15 PM
MARIO121
It is a Toyota tercel 1997 with a 1.5 l engine.
Thursday, October 25th, 2007 AT 6:44 PM
