1991 Toyota Tercel Cylinder Head Torque Sequence
1991 TOYOTA TERCEL
152,662 MILES • 4 CYL • 2WD • AUTOMATIC
KAHART
I just removed and replaced the head gasket on my daughter's 1991 Toyota Tercel. I have the torque specifications, but I cannot find the Torque Sequence. Can you assist?
Jan 1, 2009 at 7:03 AM
DSPLC
  • 220 POSTS
The cylinder head bolts should always be tightened gradually in several passes using the correct sequence. As per Haynes Manual for Toyota Tercel 1987-1994: First round in sequence tighten to 22 ft/lbs, then second round tighten to 36 ft/lbs, then go back in third round and tighten each bolt another 90 degrees (or a 1/4 of a turn) or what you know specified torque specifications. For 3E-3EE engine
https://images.2carpros.com/forum/automotive_pictures/89255_3E3EE_cylinder_head_1.jpg
Jan 1, 2009 at 12:09 PM
KAHART
DSPLC,
Thank you!! I appreciate you taking the time to respond to my question. What is the liklihood that there will be adverse effects from tightening them in the exact opposite order if the Haynes Manual 22 ft/lbs, 36 ft/lbs and 1/4 turn torque spec was followed?
Jan 2, 2009 at 3:06 AM
DSPLC
  • 220 POSTS
I have never done it on the opposite sequence but the warning in the manual states the following:
Failure to follow this procedure exactly may cause either premature gasket failure or head damage
Jan 2, 2009 at 5:53 AM
