1987 Toyota Tercel coolant
249,000 MILES • 4 CYL • FWD • MANUAL
ROXYMAYE
I just replaced my radiator and although I drained the cooling system there is still water in the expansion tank. I have a premix of ant-freeze and coolant that says "Do Not Mix with water" Is it okay to use water alone as a coolant for a short time?
Apr 12, 2008 at 6:04 PM
  • 31,937 POSTS
Hi there,
Yes you can just use water , as long as you are not in a area that will have freezing temp. as the coolant is a anti freeze agent as well as a corrosion inhibitor, just don't leave it to long.
mark (mhpautos)
Apr 12, 2008 at 6:12 PM
