1995 Toyota Tercel Leaking Water
1995 TOYOTA TERCEL
211,000 MILES • 4 CYL • FWD • AUTOMATIC
AZTLANFIGHTER
When accelerating pressure is causing coolant to be pushed out of the overflow tank next to the radiator, and the radiator is bone dry and keep having to put water in it else it over heats. Not seeing any visible leaking from anywhere else and was wondering if you folks could gimme some advice
Jun 2, 2010 at 10:37 AM
  • 31,937 POSTS
Hi there, check that the radiator is not part blocked, replace the thermostat and have a head check done, this is a simple chemical test to see if there is any exhaust gasses in the cooling system, start here.
mark (mhpautos)
Jun 2, 2010 at 10:44 AM
