1987 Toyota Tarago Car runs fine, but won't start once I tu
LAMAMU
  • 1987 TOYOTA TARAGO
Engine Performance problem
1987 Toyota Tarago 4 cyl Two Wheel Drive Automatic
my car runs fine, will start with no problems, but once I turn it off, it wont start again for 30-60 minutes. After that amount of time, it will start with no problems. It tries to start, it just doesnt catch. Please help
Sunday, May 16th, 2010 AT 8:48 PM
Next time it refuses to start don't wait do below immediately to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, May 17th, 2010 AT 12:19 AM
