Engine Mechanical problem
1997 Toyota Tarago 4 cyl Four Wheel Drive Automatic
The 60A fuse for the glowplug relay blows wnenever it is used. The engine will not fire without the plugs working. There is a chance thre last owner didn't change the plugs all at the same time and one does look different, without removing them.
I've tried up to an 80A fuse, still blows immediately ignition on.
Nov 27, 2008 at 11:22 AM
