WILL NOT START Clicking noise coming from the starter relay
MELDRIDGE82
  • TOYOTA TACOMA
  • 4 CYL
  • 4WD
  • MANUAL
  • 83,000 MILES
Sometimes when i try to start my truck a clicking noise comes from the starter relay located on the passenger side under the hood mounted on the wheel well. what could be causing this and how could i test it. can i bypass this somehow and not cause more bad than good?
http://www.2carpros.com/forum/automotive_pictures/350305_Mark_001_2.jpg
http://www.2carpros.com/forum/automotive_pictures/350305_Mark_002_2.jpg
http://www.2carpros.com/forum/automotive_pictures/350305_Mark_003_2.jpg
Wednesday, April 29th, 2009 AT 9:25 PM
Try swapping the starter relay with a like one and see what happens and also check the clutch switch
Wednesday, April 29th, 2009 AT 9:38 PM
MELDRIDGE82
  • 5 POSTS
I have pushed that safety switch on the left side of the steering wheel to bypass the clutch swtich and it still does it. But I will try to find one like the one on there. The only bad thing is that it only does it every once in a while. But it is starting to do it more.
Wednesday, April 29th, 2009 AT 10:02 PM
Related Engine Not Running Content
