2001 Toyota Tacoma my truck will not fire
MUDMAN01
  • 2001 TOYOTA TACOMA
  • 4 CYL
  • 4WD
  • MANUAL
  • 75,000 MILES
I blow one motor up and I got an other motor from a juck yard and I changed all of the senders and sencers all of the wires are hocked up right I got power to the coil packs but I dont have any spark from the spark plugs.
what can I try to do to fix it? Thank you josh sprout
Saturday, February 13th, 2010 AT 10:32 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, February 15th, 2010 AT 2:55 AM
