2008 Toyota Tacoma
MANORRIS
2008 Toyota Tacoma 6 cyl
The truck won't run, the fuel pump is not getting any voltage.
Oct 30, 2010 at 7:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuses and fuel pump relay
Oct 30, 2010 at 7:08 AM
MANORRIS
I have checked the ones I can find. I don't have the owner's manual, so could there be another fuse/relay somewhere else that controls everything?
Oct 30, 2010 at 8:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
theres only one fuel pump relay and it is at the left front of engine compartment. the info. i have on the fuses is not showing a specific fuel pump fuse but if you have a light tester it only takes a few minutes to go through and test all of the fuses.
Oct 30, 2010 at 8:29 AM
