Well that sensor could be bad. I have had new ones not be good or not last long. I would check the vacuum hose to the throttle opener and make sure there are no leaks or cracks on that vacuum line. If that looks good then I will look over the range chart for the tps and you will need to do an ohms test on it and you will also need to be able to apply vacuum to the throttle opener for that test. Let me know what you find.
May 21, 2009 at 2:26 AM
