1994 Toyota Tacoma
185,000 MILES • 6 CYL • 4WD • MANUAL
ATITSWO
It has no power when accelerating in 1st, 2nd, & 3rd gear, but once it is in 4th gear, the truck gets power and seems fine. There is no warning light on, and I was just wondering what I could do to increase the power in the lower gears. It acts like it is smothering down until 4th gear.
Aug 29, 2010 at 7:57 AM
  • 75,988 POSTS
You sure the clutch is not slipping?
Aug 29, 2010 at 6:52 PM
ATITSWO
It wont take fuel it acts like its suffering for fuel.It cranks good it idols smooth.
Aug 30, 2010 at 9:02 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if ok, test the airflow meter and the throttle position sensor-
Aug 30, 2010 at 10:59 AM
