2001 Toyota RAV4 Idle Control Valve
JOSHER
  • 17 POSTS
2001 rav 4, 142,000 miles
can i test the idle control valve off the vehicle to make sure it is the part i need/ It is$220.00 dollars, i'd like to be sure...if so, how do i do this?
joe
Mar 28, 2006 at 2:25 AM
LOSONE
  • 1,616 POSTS
The only thing you can do is clean the valve in a static position. Perhaps u shuld try an after market. Often times they are OEM parts packaged in another box Good luck
Apr 3, 2006 at 6:32 AM
Suggested Repair
The idle control valve cannot be fully tested off the vehicle. Clean the valve in a static position, and if replacement is still needed, consider an aftermarket unit, which is often an OEM part in different packaging.
Conversation Summary
A 2001 Toyota RAV4 owner with 142,000 miles asked how to test the idle control valve off the vehicle before spending about $220. The expert said the only off-vehicle option is cleaning the valve in a static position and suggested an aftermarket replacement, noting these are often OEM parts in different packaging.
