1997 Toyota RAV4 Long Crank
SONG7
109,000 miles 4 cyl.
just got my timing belt replace ever since then it takes a little bit longer to crank. what kind it be? also its been about 2yrs since i had sparks plugs replace. can that be the problem..
Sep 29, 2007 at 6:34 PM
BMRFIXIT
  • 19,053 POSTS
[quote:7b8138b516="song7"]109,000 miles 4 cyl.
just got my timing belt replace ever since then it takes a little bit longer to crank. what kind it be? also its been about 2yrs since i had sparks plugs replace. can that be the problem..[/quote:7b8138b516]
A good tune up may be needed !
check fuel pressure /fuel filter
good luck
let us know
Sep 30, 2007 at 12:03 AM
BUZZSAW
  • 1,198 POSTS
[quote:bbd5475f98="song7"]109,000 miles 4 cyl.
just got my timing belt replace ever since then it takes a little bit longer to crank. what kind it be? also its been about 2yrs since i had sparks plugs replace. can that be the problem..[/quote:bbd5475f98]
is prob first thing in the morning? cold start injector may be prob
Sep 30, 2007 at 10:28 PM
Suggested Repair
Perform a tune-up and check fuel pressure and the fuel filter. If the long crank occurs mainly on a cold morning start, also check the cold-start injector. Two-year-old spark plugs may be part of a needed tune-up but were not confirmed as the cause.
Conversation Summary
The owner of a 1997 Toyota RAV4 with 109,000 miles reports a longer crank after a timing belt replacement and asks whether two-year-old spark plugs could be responsible. One expert recommends a tune-up and checking fuel pressure and the fuel filter. Another asks whether it happens first thing in the morning and suggests a possible cold-start injector problem.
